Use the Language namespace
- Last UpdatedAug 21, 2026
- 1 minute read
The language namespace is contained within the RuntimeData assembly. The general parameters for using the language namespace, and accessing namespace properties and attributes, are as follows:
- To call the current language (CurrentLanguage attribute):
Call CurrentLanguage var CurrentLanguage = ArchestrA.Client.MyViewApp.Language.CurrentLanguage; // Get property change notification from event subscription. ArchestrA.Client.MyViewApp.Language.PropertyChanged + = this.LanguagePropertyChanged; private void LanguagePropertyChanged(object sender, PropertyChangedEventArgs e) // e.PropertyName will return the "CurrentLanguage" language attribute value. - To call the current locale ID (CurrentLCID attribute):
Call CurrentLCID var CurrentLCID = ArchestrA.Client.MyViewApp.Language.CurrentLCID; // Get property change notification from event subscription. ArchestrA.Client.MyViewApp.Language.PropertyChanged + = this.LanguagePropertyChanged; private void LanguagePropertyChanged(object sender, PropertyChangedEventArgs e) // e.PropertyName will return the "CurrentLCID" language attribute value. - To call the current culture information (CurrentCultureInfo attribute):
Call CurrentCultureInfo var CurrentLCID = ArchestrA.Client.MyViewApp.Language.CurrentLCID; // Get property change notification from event subscription. ArchestrA.Client.MyViewApp.Language.PropertyChanged + = this.LanguagePropertyChanged; private void LanguagePropertyChanged(object sender, PropertyChangedEventArgs e) // e.PropertyName will return the "CurrentLCID" language attribute value. - To return the list of configured languages:
Return Languages var languages = ArchestrA.Client.MyViewApp.Language.Languages; - To return the list of configured LCIDs:
Example Title var lcids= ArchestrA.Client.MyViewApp.Language.Lcids; - To return the list of configured CultureInfos:
Return CultureInfos var CultureInfos = ArchestrA.Client.MyViewApp.Language.CultureInfos;
