Navigation Hierarchy API
- Last UpdatedAug 21, 2026
- 4 minute read
This Navigation API is exposed to retrieve content, based on a set of filter options. FilterOptions is the class you can use to specify search criteria.
FilterOptions Class
/// <summary>
This class holds the filter options applied to a specific navigation item.
/// </summary>
public class FilterOptions
/// <summary>
/// Gets or sets option Levels of Search.
/// Provides the levels of search performed on the hierarchy of a navigation path.
/// </summary>
public LevelsOfSearch LevelsOfSearch { get; set; }
/// <summary>
/// Gets or sets the option NavigationSearchMode.
/// Provides the navigation search mode for the given navigation path.
/// </summary>
public NavigationSearchMode NavigationSearchMode { get; set; }
/// <summary>
/// Gets or sets SortOrder option.
/// SortOrder controls how items are sorted after they are returned to you
public SortOrder SortOrder { get; set; }
/// <summary>
/// Gets or sets option ContentType
/// 1) This field should be one of the content types in the system
/// 2) This field is ignored if the value is empty.
/// </summary>
public IEnumerable<string> ContentType { get; set; }
FilterOptions Search Options
FilterOptions can be applied to searches and include the following:
- ContentName
- ContentTypes
- SortOrder
- NavigationSearchMode
- ContentData (Return Type)
ContentName
The ContentName option specifies the name of the content that you are searching for on a particular navigation hierarchy path.
- The value of ContentName must be the partial or exact name of the content.
- Wildcard characters can be used.
- The value of ContentName is ignored if it is empty.
ContentTypes
The ContentTypes option specifies the type of content that you are searching for on a particular navigation hierarchy path.
- The assigned value of ContentTypes must be the exact content type of the content.
- The value of ContentTypes is ignored if it is empty.
- If more than one ContentTypes is specified, it is supported as an array.
ContentType
// This example gets content with the ContentType of "faceplate."
searchResult = navModel.GetContentInHierarchy(@"\\Home\Root1", new FilterOptions() { ContentName = "*",
ContentTypes = new string [] { "faceplate" }, LevelsOfSearch = LevelsOfSearch.SearchesOneLevel,
NavigationSearchMode = NavigationSearchMode.ChildrenAlone });
// This example gets content with the ContentType of "faceplate" or "overview."
ContentTypes = new string[] { "faceplate", "Overview" }, LevelsOfSearch = LevelsOfSearch.SearchesOneLevel,
// This example ignores ContentTypes.
ContentTypes = null, LevelsOfSearch = LevelsOfSearch.SearchesOneLevel,
// This example ignores ContentTypes while searching child nodes.
{ ContentName = "*", LevelsOfSearch = LevelsOfSearch.SearchesOneLevel,
// This example searches for any ContentType.
{ ContentName = "*", ContentTypes = new string[] { "Any" }, LevelsOfSearch = LevelsOfSearch.SearchesOneLevel,
// This example searches content with no ContentType.
{ ContentName = "*", ContentTypes = new string[] { }, LevelsOfSearch = LevelsOfSearch.SearchesOneLevel,
SortOrder
The SortOder option specifies the sorting method that is to be applied to content searches.
SortOrder
/// <summary>
/// This option controls how content searches are sorted from the API
/// </summary>
public enum SortOrder
/// <summary>
/// This is the default option, which fills the control based on the order in which it finds the content.
/// This is similar to depth-first search
/// </summary>
None = 0,
/// <summary>
/// Sorts content based on name in ascending (A-Z) alphabetic order.
/// </summary>
Alphabetical
The NavigationSearchMode option specifies the navigation search mode that determines which navigation path hierarchy is considered at the API level.
/// <summary>
/// This option provides the different navigation search modes that system allows .
/// </summary>
public enum NavigationSearchMode
/// <summary>
/// In FixedLocation mode, a search starts from a specific navigation path node provided by the user.
/// </summary>
FixedLocation = 0,
/// <summary>
/// In CurrentPath mode, a search starts from the current navigation path node selected by the user.
/// This is same path as MyViewApp.Navigation.CurrentPath
/// </summary>
CurrentNav CurrentPath,
/// <summary>
/// In ChildrenAlone mode, a search starts from the child navigation nodes of a parent.
/// Node specified by the user.
/// </summary>
ChildrenAlone
LevelsOfSearch
The LevelsOfSearch option specifies the levels of search to be performed on a specified navigation path hierarchy.
LevelsOfSearch
/// <summary>
/// This option provides the different levels of search that the system allows.
/// </summary>
public enum LevelsOfSearch
/// <summary>
/// Searches all levels of a navigation hierarchy.
/// </summary>
All = 0,
/// <summary>
/// Searches only one level of a navigation hierarchy.
/// </summary>
SearchesOneLevel,
/// <summary>
/// Searches two levels of a navigation hierarchy
/// </summary>
SearchesTwoLevels,
/// <summary>
/// Searches three levels of a navigation hierarchy
/// </summary>
SearchesThreeLevels
The return type of the API is an array of the ContentData. The ContentData array contains information such as the name of the content and its owning object.
ContentData
/// <summary>
/// This class holds content information, such as name and owning object. /// </summary>
public class ContentData
/// <summary>
/// Gets the name of the content.
/// </summary>
public string ContentName { get; }
/// <summary>
/// Gets the owning object of the content.
/// </summary>
public string OwningObject { get; }
