OMI SDK
Settings namespace attributes
Use attributes in the Settings namespace to enable various options for showing trends, PV, SP, and other operational parameters.
Attribute Name Description Data
Type
Read/ Write
TrendDuration Gets or sets the length of a trend duration in minutes. Default is 15. integer R/W
GridLines Shows or hides grid lines on a pen trend. Default is true (shows grid lines). Boolean R/W
PVVisible Shows or hides the process value of a Situational Awareness Library symbol. Default is true. Boolean R/W
PVOptimalRangeVisible Shows or hides the optimal range indicator on a Situational Awareness Library symbol. Default is true. Boolean R/W
PVOperatingAutoScale Enables or disables meter auto scaling on a Situational Awareness Library symbol. Default is false. Boolean R/W
SPVisible Shows or hides a Setpoint on a Situational Awareness Library symbol. Default is true. Boolean R/W
TrackerVisible Shows or hides a tracker line on the meter of a Situational Awareness Library symbol. Default is true. Boolean R/W
LabelVisible Shows or hides the label on a Situational Awareness Library symbol. Default is true. Boolean R/W
EngUnitsVisible Shows or hides the engineering units of a Situational Awareness Library symbol. Default is true. Boolean R/W
ControllerOPVisible Shows or hides the Controller Output for a Situational Awareness Library symbol. Default is true. Boolean R/W
AlarmIndicatorVisible Shows or hides an alarm indicator on a Situational Awareness Library symbol. Default is true. Boolean R/W
ControllerOPCmdVisible Shows or hides the Output Command for a Situational Awareness Library symbols. Default is true. Boolean R/W
ChartRangeIncrement Sets the precision of the incremental range of chart values shown as measurement lines of Situational Awareness Library Dashboard symbols. Default is 5. integer R/W
SafetyVisible Shows or hides a safety indicator on a Situational Awareness Library symbol. Default is false. Boolean R/W
EnableDisableSound Enables or disables alarm sounds. Default is true. Boolean R/W
ShowControlLinks Shows or hides the control links of a Situational Awareness Library symbol. Default is true. Boolean R/W
ShowToolTips Shows or hides the tooltips of a graphic. Default is true. Boolean R/W
ToggleSPTag Toggles between a Setpoint or tagname value on a Situational Awareness Library symbol. Default is false. Boolean R/W
DisableHorn Enable or disable an external alarm horn. Default is false. Boolean R/W
AckAll Enable or disable the acknowledgement of all alarms. Default is false. Boolean R/W
PenTrendVisible Shows or hides all pen trend lines of a trend symbol. Default is true. Boolean R/W
OptimizeForTouch Enable or disable optimization for touch operation. Default is false. Boolean R/W
ReadOnly
This attribute is deprecated as of the System Platform 2020 release. See the  MyViewApp.ViewApp.ReadOnly attribute for more information.
Boolean Read
